Old 07-07-2009
BELLATRIX1965's Avatar
BELLATRIX1965 BELLATRIX1965 is offline
Maine Member
BELLATRIX1965 is on a distinguished road
Sounds like an air leak!
You are correct in assuming that the primary filter should be totally full!
Sounds like an air leak in the suction line, or since the filter was just changed it is more likely a cut or not properly seated gasket on your primary filter housing. Always go to the last thing that was touched if you start having a problem! Good luck!
