SailNet Community - View Single Post - COB Reality
Thread: COB Reality
post #5 of Old 07-08-2009
sailingdog
One reason it is preferable to attempt the pickup under sail, is that the engine is not always an option. While, you can often fire up the iron genny, if that is all you practice doing, I can pretty much guarantee that the one time you have a real MOB situation, the fuel filters will be clogged. Ideally, you should practice recovering MOB under both power and sail.
The engine on most sailboats is an auxiliary and should be treated as such. The motion of the boat is often far better when the sails are up and there is less risk to the person in the water if the prop is not engaged.
sailingdog is offline
