yeah, but if you have a foot switch at the head, won't it be pumping water out at the galley at the same time, unless you go for the more expensive pressure water type faucets, in which case you might just as well have a full pressure system in any case, and not bother with installing the switches....
Originally Posted by timebandit
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
