Old 07-08-2009
eolon eolon is offline
eolon is on a distinguished road
I oil my teak decks and cockpit gratings once a year. I use a Tung oil / linseed oil / UV blocker mixture, I forget the name; I have seen the Tropical oil, but I have not used it specifically. Correct me if I'm wrong, but I think it is also mostly Tung oil, with UV blockers. I try not to think about how many baby Tungs had to die to make that stuff...
I have found that you must have clean teak before applying the oil. You don't have to use those "teak cleaners" and acids and bleach and two-part whiteners, which are just going to eat away the surface of the wood. Before I apply the oil I scrub the deck with a soft brush and 5pic 'n Span, rinse really well, let it dry in the sun. Two coats with a cheap brush makes the teak look really great.
If you put the oil over dirty teak it turns very dark and muddy looking, trust me.
By the end of the season (great lakes) the sun has oxidized the oil back to the natural grey teak look.
I use Cetol on everything else (original Cetol) and it holds up very well; I just touch it up every once in a while. The bowsprit gets Captain's varnish, and I'm lucky if it lasts three months in the tropical Ohio sun.
Best Regards,
e
Last edited by eolon : 07-08-2009 at 08:10 PM. Reason: Ha Ha Ha! they blocked "S_p_i_c" !!!!
