Old 07-10-2009
WindermereColvic WindermereColvic is offline
WindermereColvic is on a distinguished road
Thanks for everyones help so far.
Is there an easy way to see if the mounts are ok? Ive been told i could just try and lever the engine up, and if it moves then the mounts have failed, does this sound reasonable?
Most of the things suggested by Maine Sail have been discounted, but im starting to wonder if we have been too hasty. This is why we have discounted them, does this sound ok?
Bent prop-Visually inspected, no impact ect since it all worked
bent shaft- visually fine, and runs fine at full RPM
misaligned- has been realigned to check
slipping transmissionthis is what we think it is, but its proving hard to find anyone willing to test our gearbox
Failed cutlass bearing - Shaft will not wobble by hand, squeeks healthily
Loose strut- Which strut?
Bad engine valve, timing, fuel adjustment - engine runs fine in neutral and reverse.
Thanks again, Matt
