The problem is the various offered formulations of Cetol is that when it, eventually over years, builds to a thick coating, ... it will CRACK/craze. Its a hard alkyd base that doesnt flex. like "spar' varnish nor the other softer or flexible 'modern' coating systems. If you've ever had the 'pleasure' of removing/stripping broken/cracked Cetol you'll rue the day you ever put this 'stuff' on your brightwork.
