SailNet Community - View Single Post - Sailboat Modifications
post #10 of Old 07-14-2009
scottyt
tide water it can be simple
just use some 8 pvc pipe with some sort of cap, then a pipe clamped on to the boat to run out to the out rigger.
or use heat to put a bend in the 8 inch pvc to give the ends an up turn. belive it or not if you put the pipe supported at the ends and just let the sun hit it it will sag, might be faster if you painted them black thou
scottyt is offline
