SailNet Community - View Single Post - Help ID this Rope Clutch
post #8 of Old 07-15-2009
sailingdog
IMHO, the best line clutches are the Lewmars. The mechanism they use is the easiest to adjust under even the heaviest load and does the least damage to the lines. Spinlocks can often jam under high loads, requiring you to ease the load on them using a winch prior to releasing them. They are also among the least expensive of all the line clutches.
However, Lewmars, due to the "domino line clutch mechanism" they use, have the smallest range of line sizes they can handle, and need to be sized appropriately for the task.
Be aware that the Lewmar line clutches open in reverse compared to many other brands... and note the little winch icon and arrow on the line clutch when installing them.
sailingdog is offline
