SailNet Community - View Single Post - Catalina 22 Swing Keel wobble
post #3 of Old 07-16-2009
Ogrenaut
Ogrenaut's Avatar
According to Practical Sailor, your swing keel is about 550 lbs of cast iron. Sounds like an expensive part of the boat just to be thrown away, not to mention what the sudden change in ballast could do to the stability of your boat. Would you drive your car if you knew the lug nuts on the wheels where loose or worn? Fixing the swing keel now sounds a lot cheaper than replacing it later.
Greg
s/v Selkie
1972 Bristol 32, #64
"Our doubts are traitors,
And make us lose the good we oft might win
By fearing to attempt."
Shakespeare
Ogrenaut is offline
