SailNet Community - View Single Post - CS36T Cap Shroud
post #23 of Old 07-16-2009
prior
prior's Avatar
ISOMAT 1982 CS Shroud cap
Hi John
I have a 82 cs36T. The spreader caps appear to be pressed and maybe flush rivited to the actual spreader. The shoulds are retained by a 1/4" ss special bolt and bushing which rotates. Mine were siezed and had to be carefully cut out. Then I replaced the bolt with a rubber bush, lanocote and covered the whoe thing with rigging tape due to the unreasonable cost of new spreader boots.
Also I used a rigging guage to check my tensions and found they were very low. I would imagine loose rigging would lead to the shroud coming adrift. Mine were held in place by the rigging tape only prior to the tension adjustment.
Paul
Three Rivers
prior is offline
