SailNet Community - View Single Post - GPS USB connector to VHF
post #8 of Old 07-17-2009
sailingdog
Yes, the NMEA IN + wire from the VHF should connect to one pin (3 IIRC) and the NMEA OUT + wire from the VHF should connect to pin 2. The NMEA IN - and OUT - wires should connect to Pin 5.
Originally Posted by macsailor View Post
I also have my old Map76, it has a cable with an small connector on the end, DB9 (?). What you are saying is this cable should plug into the the Map76Cx and provide the signal required for the VHF.
It is too bad someone does not produce a GPS puck for this application, it could sit near the VHF and be a dedicated GPS just for this purpose.
thanks again, Bob
sailingdog is offline
