Old 07-18-2009
fullkeel7 fullkeel7 is offline
fullkeel7 is on a distinguished road
Hey groupa, welcome to sailnet.
IIRC, there were two versions of the C34, one sometimes refered to as the 'bubble top' and the other with a much longer coach roof and they had different interiors. Which one are you looking at so if there is a member with that particular model, they'll be able to help?
Anyway, it may take a little while for right person to see your post. Does't happen ALL the time, but more often than not, you'll usually get some help. In the meantime, enjoy the humor. Although sometimes a little skewed, it's all usually good natured and I found it takes a little time to learn the dynamics of it all. I also find that 99.9% of the members here are most knowledgeable in a lot of different areas pertaining to all things sailing and will bend over backards to help a fellow sailor. I've had more than my share of coffee laidened nose spews with some of the humor and consider it 'value added'. Relax a little and enjoy the ride while waiting for your specifics... Good luck with the prospective boat.
