SailNet Community - View Single Post - Catalina 25 Good Only Good for Bays and Daysailing?
post #8 of Old 07-20-2009
mdbee
Large Member
Another thought..
Check the areas you want to sail in. Many of the bays around here are pretty shallow. You may want to consider a swing keel, swing board or dagger board. There are times we are in only a couple feet of water in certain areas. . Water ballast can also be handy if you find yourself grounded. Simple matter of blowing the water out and gives you a few more inches of water under you.
Originally Posted by yippeekayay View Post
Just wanted to know first, if this boat is a good buy? Understanding that it checks out with all the pre inspection tips.
Also, is it good only for bays and daysailing or can you go overnight and/or a few weeks on it. I will be sailing in the Southern Coast of texas in the Gulf of mexico if i can on this boat. Or should i be looking for something bigger?
Catalina 25 sailboat for sale
Thank you,
Brandon
mdbee is offline
