Outboard size for 23ft sailboat
For small boats, engine power is related to boat displacement. A sailboat outboard should be a small as possible (low engine weight and correct proppellor pitch) The last one is mostly forgotten.
The formula is roughly, 4 hp per 2200lb
Then go to the internet to find a propellor calculator to determine your propellor size.
Petrol engines are mostly lighter than diesel (Tohatsu)
Good luck!!
Best Regards from the SARI Captain To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
