Should transmission be in gear when sailing?
Good advice Paulo.If you do not know that, you better do some reading up on your particular transmission because it can lead to serious damage ,besides that, there are probably other things you will learn in the process that you are neglecting or have overlooked.The worst thing you can do is take anything you heard from someone down at the dock as fact(learn all you can about your equipment).These posts should get you thinking,then do your investigating.
