SailNet Community - View Single Post - painting the side strip of my boat
post #4 of Old 07-23-2009
Sailormann
Here .. Pull this
You can easily use vinyl there as well. Many boats do so. There is a vinyl that comes with a clear upper layer that you peel off leaving a very thin permanent stripe - it's about the same depth as paint and much easier to get a perfect finish.
Be careful when you are applying the tape. You need to stretch it a little bit to conform to the curves of the hull, but do not stretch it too much or it will bag.
Sailormann is offline
