SailNet Community - View Single Post - Florida to New York
post #2 of Old 07-23-2009
camaraderie
moderate?
camaraderie's Avatar
That's barely time for the one way trip if you are going offshore.
Suggest you have damn good weather reports...perhaps a router like Chris Parker or Jennifer Clarke as this is definitely a dangerous time of year to be leaving anything to chance. SSB radio/fax would be helpful.
Suggest also that wherever else you plan to stop...you plan to put in at Beaufort NC...this will let you stop and wait for a great forcast for rounding Hatteras in calm conditions and make the run up to the Chesapeake with favorable winds/seas since there is no where else to put in if it starts getting gnarly. From the Chessie to NYC is 3 days.
Beaufort from Jax should be 4-5 days. Can you do the Hudson and the Erie and pull the mast in the remaining time?? Dunno and obviously everything is weather dependent. Suggest you have a few bailout alternatives in mind rather than try to push it all at once if the weather does not cooperate as that is when boats get into trouble.
Good luck!
camaraderie is offline
