SailNet Community - View Single Post - Headsail choices
post #9 of Old 07-24-2009
paulk
paulk's Avatar
If you're getting that much backwind in that little air, it sounds like the main needs flattening. Is your backstay good and tight? Vang on at all? Outhaul and cunningham? Sheet socked 'way in? You have probably already done all these things. Next step might be to try opening up the slot by barberhauling the jib OUTBOARD, perhaps with a snatch block on the rail. This will affect your pointing ability (though perhaps not really that much) but could increase speed markedly. Otherwise, it could be that your main is simply too blown out and baggy, and you need to give Omar the tentmaker a call about a getting yourself a new (flatter) main.
paulk is offline
