SailNet Community - View Single Post - Florida to New York
post #6 of Old 07-25-2009 Thread Starter
RLMToronto
Thanks
Thanks for the input all.
I do indeed plan to keep the options open, even to the point of trucking it home if the weather looks like it's not going to cooperate. Had also planned on using the routing service. And may do as some suggest, use the ICW past Hatteras if conditions look bad. Volkhard's your comments interesting in this regard. Would you rather have been outside given the conditions?
I'm considering getting the weather sat. antenae for the HDS-5 Lowrance unit to aid in the weather info. Any thoughts anyone?
BTW, the canal can apparently be done in 4-6 days, but I'm not certain whether that is from Troy or from NY, and is probably by motor boat which can do a little higher speeds where allowed.
RLMToronto is offline
