SailNet Community - View Single Post - Yanmar Oil Pressure
post #3 of Old 07-28-2009 Thread Starter
Doug K
Yanmar Oil Pressure
Thanks for that advice on fuel in the oil. We just ran the engine pretty hard on a ten day cruise around the Delmarva Peninsula with out much wind. I am about to change out the oil with Rotella 15w-40w. We had been using Castrol 15w-40w. The engine is starting to get into the 190 degree range when I run the rpm's above 2200 leading me to think heat exchanger needs to be serviced. I'll change out the impeller as well. I was thinking the high temps may have something to do with a drop in oil pressure.
Searunner37 is offline
