SailNet Community - View Single Post - Singlehanding Pearson 35 Centerboard
Old 07-29-2009
mitiempo's Avatar
mitiempo mitiempo is offline
Regardless of the boat, singlehanding depends a bit on your experience and a lot on how the gear is set up. By running halyards and reefing lines aft to clutches and then a winch on the cabintop it's a lot easier. For the jib rig a downhaul by leading a light line through a small block at the tack and thread it through the hanks to the head. Sheeted in drop and pull down with the downhaul and it should fall inside of the lifelines. If you have furling it's easier. Lazyjacks to contain the main are helpful too. If the boat is larger the sails are heavier but the winches are bigger as well. Main difference on a larger boat is to think ahead.
Brian
