SailNet Community - View Single Post - What is it with....
post #19 of Old 07-30-2009
What is it with females?
When you are hot, you think that by cranking down the ac to a lower number it will suddenly blow out colder air! All that does is set the stop temperature, gals. It won't get any colder. But here's a little hint: When you crank it down that low, go for a ride with the kids and hubby in the dink, and come back to see ice cycles hanging from the cyling in the Middle of July, don't be suprised when your husband does not talk to you for a few minutes!! So I ask ya... what is it with girls?
Okay, the engineering answer is: turn the a/c all the way down because when you decided to save money and do the installation yourself, you forgot to make sure air could get to the temp sensor so it would operate properly (you dork!) Or because its not really the heat at all, its the humidity that you're fighting. Or because she's really in the mood to cuddle but your sweaty stickiness is a turnoff
eryka is offline
