SailNet Community - View Single Post - Mixing AGM and wet cell batteries
post #7 of Old 06-11-2005
928frenzy
Thanks for the reply. I returned the deep cycle wet battery for one that had more cold cranking amps, but not deep cycle. I''ll install it tomorrow as my starter battery "only", unless there''s an emergency.
The new charger has a feature that allows for three stage charging (which charges in spurts up to 14.2 volts). The charger is presently charging the AGM batteries at 13.6 volts. I plan to connect the starter battery to the charger. Should I install the three stage module?
~ Happy trails and sails to you ~ _/) ~
928frenzy is offline
