That's good to hear. Just out of curiosity where did you get your lift bags? I was looking into renting them from
Rental Tools Online - Specialty Tools and ROVs for Hazardous Locations, Underwater, and Emergency Services.
or buying them from
http://www.proliftbags.com/index.html
But after seeing the shape she was in in person my budget for recovery shrank.
There are a lot of ideas and opinions in this thread about how to get her out on the cheap. The reality of the situation is without professional lift bags (or a tugboat or crane) it's gonna be a lot of work to get her out.
So here's my two cents or what I had planed for my recovery attempt. I'm not sure if you've seen her in person or not but it sounds like you have all your ducks in a row and you will be raising her on the 15th. So I hope my advice is of some use.
I planned on renting or buying four 6,600 lb lift bags. I figured with double the weight of the boat in lift capacity she'd have to float. Your biggest obstacle is going to be getting the straps under the hull to attach the starboard side lift bags to. You said you have a diver so that should help a lot in that task. The mud is fairly soft and pushing the straps under the hull may work. Or starting them from each end and using a come along to pull them towards the center. I had planed of placing two straps under the hull one in front and one behind the keel. And running two straps along the length of the keel to attach the two bags on each side together (to keep them from slipping out of position).
After swimming around Distant Star for about an hour yesterday I came to the conclusion (if I got the chance to float her) that I would place straps as mentioned above, attach the bags, and float her in her current position i.e. on her side. Tow her into deeper water where the weight of the keel should do its job. Once in deeper water if the weight of the keel is not enough to straighten her out you should be able to get her vertical with a little help from your friends. Then fire up the old trash pump, and in a few minutes she'll be floating on her own. I addition to the lift bags I also considering filling the cabin with various things to increase the overall buoyancy. One thing I thought might work would be bunnage bags
Home - Dunnage Air Bags
There pretty cheap but I never got around to finding a local supplier and testing them to see how tough they are.
Anyway, I wish you luck and I hope my two cents were of some use.
p.s. let me know what time you'll be out there I may be able to muster a few good men to come help you out.
