SailNet Community - View Single Post - VHF antenna question
post #4 of Old 08-02-2009
SEMIJim
Originally Posted by mitiempo View Post
Pegasus
Try checking the masthead antenna for continuity between the shield and central wire. A friend had the same problem recently and if you get continuity it means it's shorted out somewhere and needs replacing or fixing.
That is not necessarily correct. It depends on the antenna design. Some antennas will measure close to zero ohms DC resistance normally.
Jim
SEMIJim is offline
