SailNet Community - View Single Post - Drilled Hole in Hull Repair
post #4 of Old 08-04-2009
Sabreman
Sabreman's Avatar
I had a similar arrangement on my last boat.
You need to fill the hole:
1. Taper the inside and outside of the hole so that it's no longer a 90 degree edge. Sort of like a sink drain.
2. Remove all traces of paint on the inside and outside. Wipe with acetone
3. Obtain fibreglass roving cloth. Cut several pieces the size of the hole
4. Tape over the outside of the hole with masking or duct tape to temporarily seal the hole.
5. Mix up some West Epoxy or equivalent, soak the roving, and insert in the hole. Repeat once more. Tamp gently to remove air bubbles (This is really important). Let stand until hardened
6. Remove the tape from the outside
7. Repeat #5 until desired thickness is achieved. Make sure to remove all air bubbles.
8. Cut and epoxy a larger cloth piece to overlap the edges of the hole by about 1" and apply to the inside of the hole.
9. Mix collodial silca to thicken the epoxy and fair the outside of the hole.
Sabre 38 "Victoria"
Sabreman is offline
