SailNet Community - View Single Post - Drilled Hole in Hull Repair
post #8 of Old 08-04-2009
baboon
One option to consider is to leave the transducer in place. It is a solid plug and has no moving parts. Many feel the depth sounder is the most important instrument, and having a back up ready to go is not a bad idea. A through hull transducer will also be more acurate, although I understand the newer surface mounts are pretty good. It seems different manufactures of displays use the same transducers so you may have options as to how to read the depth.
baboon is offline
