SailNet Community - View Single Post - Sail Slugs comming out of the slot
post #4 of Old 08-05-2009
chucksk
"Metal Mast" slides have different dimensions than the standard nylon or plastic slides. I had a similar problem until I replaced the 3/4" slides with metal mast #8 slides which are 0.9" wide. There is also a metal mast #6 slide available which may have the correct dimension for your mast. Metal mast slides are available from Sailmaker's Supply.
Chuck
chucksk is offline
