SailNet Community - View Single Post - Anchor Set Up
Thread: Anchor Set Up
post #6 of Old 08-10-2009 Thread Starter
chef2sail
chef2sail's Avatar
Our usual procedure for anchoring is me dropping the hook in a controlled free fall so the chain does not just pile on top of the anchor. We have a manual windlass so this is actually quite easy. Once my scope is 5X depth my wife put the engine in reverse and makes sure the anchor is set properly under load. I would then let out the appropriate scope. The reason we did 12X is that they were actually calling for SMW of 18-22 knots.
What was so amazing about this is that the chain parted at the 30 foot mark. It wasn't the case of a loose shackle or failed one as there was originally 60 feet of chain. We also appropriately had 3 wraps of seizing wire on the shackle.
Cam thanks for the advice on the snubber. I was figuring the "give" in the nylon rode will take up the shock. Even though we primarily anchor in the Chessie we also take some long trips every year. This year we went to Mystic and Block Island and next will be Newport, Cuttyhunk. Martha's Vineyard and Nantucket.
I only thankfully the chain didn't part when we were anchored in Branford between two rock groups called Big and Little Mermaid.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
