Old 08-11-2009
Cruisingdad's Avatar
Cruisingdad Cruisingdad is offline
Best Looking Moderator
Originally Posted by phoenix3 View Post
I am the original ownerof a C400, hull #87. My Westerbeke 42B diesel just failed last weekend while I was on vacation. Compression check showed poor compression in all cyl. (130, 100, 205, & 180). If you have had or are aware of this problem, what did Catalina or Westerbeke do about it. I know that the problem existed with 42B's in hull#'s 1 through 99. I have received quotes of $10,000 - 12,000 to replace the 42B with a Westerbeke 44. Any information on previous repairs and the Westerbeke/Catalina response is appreciated.
Thanks, Everett Rezendes
"Phoenix III"
Hull#87
What is the exhaust size coming off the diesel? It should be 3" as I recall. I understand that there was a back pressure issue with too small of exhaust causing a BP in excess of 10psi. It should be about 2 or so at WOT.
If you have a smnall diameter hose, better look into that first. Won't save your engine, but might save the next. All of this info happened before I was tech editor so I am giving you second hand knowledge from the previous tech editor.
Also, what about repowering with a Yanmar? The new ones (including mine) are all 54 hp. It is more than you need most of the time, but maybe not when in a strong current or blow. I would not trade it down to a Westerbeke of lower HP.
My opinions.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
