That is before my time. Mine is a Mark II, yours probably a MkI. I suspect that it would fit without a problem.
if you did everything thta they suggested, including the exhaust (3"), then the damage was either done before hand or it is what Catalina always said: a defective engine. I might suspect the latter - but again, I am commenting on things I know very little about except second hand.
I will get the appropriate person on here to help you. Hang tight.
Brian
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
