Hi Negrini
Thank you for your input. Yes I was confused. I now have the AIS connected directly to the C70 (with the correct polarity) via the NEMA In.
The AIS is working I have checked the baud rate and all is fine there.
The antennae has checked out by testing with the VHF radio.
The AIS icon in the C70 still shows a cross thru it but that was the case when I initially installed the AIS.
At that time The system seemed to come alive when an AIS signal was received while we were underway.
I think this may be caused by the AIS alarm being turned off. However turning it on did not change the icon status.
I will do a test later today and keep you advised.
Thanks again for your input.
Sirromcd
