SailNet Community - View Single Post - Instrument panel came right out
post #3 of Old 08-12-2009 Thread Starter
zAr
Originally Posted by Vasco View Post
If you can't get another panel, mount everything on a piece of marine grade plywood and put that in place. The stop handle should screw off the cable. The electrical connections should be relatively easy to remove and put together again. Just draw a diagram if you're unfamiliar with them.
Well, that seems easy enough and a lot cheaper than ordering a new panel for $400 USD. Thanks!
RS
zAr is offline
