SailNet Community - View Single Post - Air blockage in cooling line.
post #12 of Old 08-15-2009 Thread Starter
L124C
L124C's Avatar
Originally Posted by trantor12020 View Post
I get this problem when I sailed for long period on port tack at >40deg heel. apparently the water intake ocassionally is out of water and water drains out causing air trap. filling up the pump discharge hose solve the problem each time.
Why would you be sailing for long periods at 40 degrees? Think it's probably time to reduce sail. You might actually move forward as opposed to sideways Generally, I think anything much over 20 degrees is excessive. Hard on the boat, sailors and counter productive. Anyway, I certainly didn't have the intake out of the water
L124C is offline
