SailNet Community - View Single Post - Bushings for 7.3 Rudder
post #10 of Old 08-18-2009
scuppers
Here you go...old SBO message with the info
The following message was posted in the S2 Owner Forum at http://www.SailboatOwners.com. ----------------------------------------------------------- Mike posted the following about a S2:
The rudder has two nyliner flange bearings(Part # 335008) one at the top and the other at the bottom.
There is also a nylon washer(Part # 534304) between the the rudder head, and the bearing.
S2 has the parts, the bearings are $19.00 each, I'm not sure on the washer cost.
I faxed S2 Sailboat Assistance @ (616) 394-7473 with a question about rudder play, and that is how I found out about them having the bearings. Hope this helps
scuppers is offline
