Originally Posted by L124C
Posted this in another forum, and now realize it was probably the wrong one. This Hunter 30 was retrofit with an electric motor. The owner told me he had a tough time finding space for 12 Batteries (I'll bet!). The boot stripe at the Stern and top of the rudder are well out of the water (not a great photo, I know). Don't know if the new motor has anything to do with it, but it appears to me she is totally off her lines, and has to be adversely affected under sail. Yes, No, thoughts?
Are you concerned with the aesthetics of how the boat looks sitting at the dock? Rather than a static photo of the boat at the dock, you need to see how the boat performs under sail. Once the boat is up to hull speed, the stern section will be deeper in the water.
While underway inspect how the water streams off the stern. Usually boats have a tendency to squat when sailing even though they are
on their lines at the dock.
A Hunter 30 is relatively small to the extent that weight placement will make a big difference. Moving all or some of the batteries aft would be noticeable but perhaps unnecessary. The same result could be attained by filling the lazaret with sails and other clutter. If your cruising with five people that could be 600-1000 lb sitting in the cockpit.
Rather than fussing over getting the trim just right at the dock, I'd take it out in a few different wind conditions to see if changes are really essential.
