SailNet Community - View Single Post - Bushings for 7.3 Rudder
post #11 of Old 08-20-2009 Thread Starter
dakuehn
dakuehn's Avatar
Deathstare,
Prior to dropping my rudder, I had been concerned by what I considered a bit too much vibration at certain angles of heel and speed, but others (more experienced) have told me not to be too worried. I was grateful that S2 had the flange bearings, but honestly it seems that a better substitute is out there to fit over the 1 1/2" stainless rudder stock (the washers can be had at most hardware stores). I consider myself lucky that my rudder stock is true and that the fiberglass tube in which it rests showed no signs of unusual wear.
One thing that did puzzle me was that the tube was not reinforced/tabbed in at the deck opening (it was obviously heavily reinforced at the bottom). I chose to do some grinding and tabbed in the tube to the underside of the deck. If one was concerned about excess wear in the tube itself, I would recommend the West System approach where you selectively drill holes and inject epoxy with the rudder stock in place (and waxed). The method is outlined in the boat repair flyer or online.
dakuehn is offline
