Pumping out a flat bilge
There are switches with two probes that will function in very little water, but the typical Rule pump itself has about a 3/4" threshold to be able to move water and depending on the hose size, some water runs back down the hose after the pump cycles. If you use a Par remote pump and flat strainer pick-up in combination with the probe type switch, you will get most of the water out.
