SailNet Community - View Single Post - tohatsu 3.5 won't run without choking
post #26 of Old 08-21-2009
flatracker
To avoid this problem
To avoid this problem in the future, if it is jet stopped up from crud, which I think you will find to be the cause. When you finish for the day with the engine, shut off the fuel and run the carb. dry. Modern?? gasoline is horrible, and while sta bil will keep it usable for some time, when it evaporates, still leaves junk behind, which stops up jets. Running it dry will eliminate this problem.
Dream like you will live forever. Live like you will die tomorrow. ( James Dean )
flatracker is offline
