Morgan''''s
The Morgan OI series were designed to provide a lot of room down below first and for sailing ability second. They were intended for use in a region with consistent winds in the mid to high teens. This means that you will spend more time motoring than sailing if you sail in an area with lighter winds. While they make good liveaboards they are not the best choice for either coastal or long range crusing. There was also a wide range of build quality on these boats from pretty junky to moderately good. These boats are getting pretty long in the tooth and should be carefully surveyed before buying one.
