SailNet Community - View Single Post - Water in the bilge
post #3 of Old 08-24-2009
jjns
you may want to check the shaft as well. We had a similar experience early on with intermittent filling of the bilge, PO had installed a drip-less seal that worked GREAT when sitting in the slip. When underway though... only found it as one day there was an odd noise and pulled the covers off while underway, whole engine compartment was a cloud with a radial spray going on at the shaft. A new, quality drip less seal solved all problems.
jjns is offline
