Old 08-26-2009
hellosailor's Avatar
hellosailor hellosailor is offline
The glue is basically rubber cement, and the solvent for that is naphtha, similar to benzene. Higher fraction solvents (like acetone) may be overkill since any kind of oil eventually softens it up. Mayonaise and peanut butter are recommended because they'll stick long enough to let the oil absorb and soften the residue up, then wipe clean without harming the fiberglass or paint.
The specialty products like 3M's adhesive remover and goo-gone are great, a bit pricey but they work fast and clean if you want to run out and buy them.
