SailNet Community - View Single Post - Vertical slide motor bracket?
post #13 of Old 08-26-2009
Pasquale
Hello John and others
I am looking for an easily removable hanging vertical slide outboard motor mount for a Nicholson 32 to be used to mount 5 hp engine for getting into a marina. It will need two horizontal struts at bottom with bumpers to push against transom. I expect to mount it to a wooden block bolted through the rear deck. I assume I will end up with some kind of welded steel tube design.
I do have a diesel engine but do not lke to rely on it.
Maybe I should just get a long sculling oar?
I would like to know how it worked out for you or other . Thanks
Pasquale is offline
