SailNet Community - View Single Post - Filling a Stanchion?
post #4 of Old 08-26-2009
mitiempo
mitiempo's Avatar
You can plug the base of the stanchion with thickened epoxy or similar and drill a drain hole at the top of the epoxy plug. A 3/16" drain is all you need and if the epoxy plug is right below the drain water won't build up. But if any foreign material gets in it would be tough to remove.
Brian
mitiempo is offline
