Old 08-28-2009
OhioTom OhioTom is offline
OhioTom is on a distinguished road
Control lines set-up for singlehanding
I have all my deck hardware removed for my deck re-core/re-paint project. I'm considering whether to alter the layout for my control lines to make it easier to singlehand.
Currently, all my control lines lead aft. I have three winches on the seahood over the companion way and a total of eight rope clutches to handle all the lines coming from the mast. My mainsail has a bolt rope in a mast groove and my headsails use a double foil (no furling). The reefing system consists of tack hooks at the gooseneck and the reefing lines led to the forward end of the boom, down to the deck at the mast base, and back to the cockpit. The boat is 26' and was set-up for racing, not singlehanding.
My concern is raising and lower the sails and reefing. The system I have needs to change, but I'm not sure what would be the best way to go.
Option 1: Move the three winches to the mast. I would be able to guide the main while I raised/lowered it, put a wrap on a winch with the jib halyard and walk it forward while raising the jib/genoa, and set/shake out reefs in one trip to the mast. I have inboard shrouds, so that should protect my sheets from fouling on the winches.
Option 2: Instead of using reef hooks on the gooseneck, I could use running reef hooks similar to a cunningham and run those back to the cockpit for reefing. I guess, with my current set-up, I could put a wrap on a winch with both the main and jib halyards and still go forward (I would need longer halyards) to guide the sails while pulling on the halyards.
I would like to hear (or maybe see with pictures) how others set-up for singlehanding. I've also considered removing the foil from my headstay and having hanks put on my foresails.
Thanks.
