Use a two-line reefing system, where one
line control's the reef's tack and another controls the reef's clew... That's how I have my boat setup, with the main halyard, topping lift, reefing
lines, and outhaul all run back to the cockpit.
The reason I went with a two-line reefing system is that I feel it gives better control over the sail shape when reefed and the lines are shorter than if I were using a single-line reefing system. The lines are also under less friction than in a single-line reefing system.
For more about two-line reefing, read this
page.
If your mast is deck-stepped, then adding a base plate to the mast step to attach the blocks for the halyards and lines being led aft is a pretty simple way to do it.
It would help if you said what make/model boat you had, since someone on this forum may have the same boat and could give you model specific advice.
POST.
