SailNet Community - View Single Post - Dark Color Hulls
post #9 of Old 08-29-2009
US27inKS
Midwest Puddle Pirate
US27inKS's Avatar
Originally Posted by wemsail View Post
Can a dark pinted hull really be overpainted with white? I would think the dark color would show through and at least every scratch or rub would bring out the dark under coat. do you need to remove the dark awlgrip first? Is this possible?
It is possible if you put enough work into it. A few extra coats of primer should do the trick. The dark gelcoat would show through a scratch just as white gelcoat would show through a scratch on a dark painted boat.
In the future, please check the date of the posts you are replying to. In this case you replied to a thread that has been dead since 2007. It's better manners to put together a full and complete question and start your own new thread. No one will beat you up for asking a well researched question that includes all of the information needed to properly answer it. Floating an old, dead thread however....
John USYacht 27 "Cora Lee"
US27inKS is offline
