Cal 29 keel bolts ?
http://www.richardanderson.net/TechS...20Brochure.pdf
In looking at a 1970 CAL 29 I did not see keels bolts ,just a lifting hoop that looked like it was used to set the lead into the hull mold
In reading the Brochure it says Lead 3350# inside integral fiberglass keel which seems good
If anybody can confirm this thank you
Yes i know about the rusting steel mast beam
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
If a dirty bottom slows you down what do you think it does to your boat To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
