SailNet Community - View Single Post - Compounding Fiberglass
post #3 of Old 08-01-2005
dsmolar
Also, it may be that you have a heavy oxide layer and need to wet sand with maybe 360/400 grit and then compound.If it''s old glass when sanding you will have to be careful not to sand to the laminate.You''ll see it start to turn dark when you get close.
dsmolar is offline
