SailNet Community - View Single Post - Sailing "Downwind"
post #6 of Old 09-02-2009
US27inKS
Midwest Puddle Pirate
US27inKS's Avatar
Originally Posted by SpcAlan1 View Post
I have a Catalina 25 with a roller furling ( without a spinneker sail ).
I can sail pretty good going up wind ( i guess most poeple can ). But when I need to head back home ( downwind ). I always seen to have a problem going anywhere.
I do not have a spin sail.
So should I use a whisker pole to push out my front sail and push the main sail out perpendiculr to the boat ( I think this is call wing-to-wing )?
But isn't it dangerous to have the boom that far away from the center of the boat?
I would hate to have my boom that far away from the center of the boat, the wind change and it come crashing across the cockpit.
Any ideas?
Or is this normal SOP?
Sailing a broad reach is the sure fire way to ensure no accidental gybe. At times though I enjoy going wing on wing. Without a whisker pole, wing on wing is a little tricky. The headsail on my boat doesn't like to stay filled without a pole. I usually sail by the lee just a bit, and it keeps the genoa full. The tricky part is avoiding the gybe without a preventer. I sail on a lake, so shifting winds are a constant battle. I only sail by the lee if the wind is coming straight up the lake and is very steady. I also run a loose vang when sailing by the lee, as it allows the top of the sail to twist forward and helps keep it on the desired side of the boat.
John USYacht 27 "Cora Lee"
US27inKS is offline
